Scrap PC not booting into POST
walkman461
14
Hey hardware-enthusiasts!
I'm trying to boot up this scrap PC (specs at the bottom) just to get into BIOS. I am not using a case and I just put my motherboard on some stacked cardboard until my case arrives.
The PC starts and keeps running every time, no matter what I try, but does never show any video output.
The motherboard doesn't seem to have an on-board speaker, so I don't get any beep-sounds either.
What I've tried:
  • ■ Without video card (HDMI and VGA)
    ■ With video card (2 different ones, both VGA)
    ■ 3 different ram sticks in both slots
    NO RAM STICKS (and it still kept running - that's why I chose RAM as category here)
    ■ 2 different PSU's
    ■ Removed the CMOS and waited for 20 minutes and put it back
    ■ Cleared BIOS settings by circuiting the two pins assigned in the manual
It has worked before with mostly the same hardware.
My question:
Is there anything I forgot to do
or
How do I check which part is malfunctioning/broken
Thanks in advance!
Specs:
Intel i5-3330 @ 3.00GHz
MSI B75MA-E33
Ballistix Sport 8 GB DDR3 1600 CL9
Cooler Master RealPower Pro 620W Modular - M620
Remove the CPU and visually inspect pins for possible damage. Reinstall and try again. At the very least, re-seating the CPU might be all that's needed.
Also, you can purchase a motherboard PC speaker real cheap. Under 2 bucks. Shipping would probably be more expensive. Consult the MB Manual as to where it should be installed. It's only going to be two pins.
