Hi,
Recently I've run into a weird problem with my Nvidia Quadro NVS 110M graphics chip on Dell Latitude d620 laptop.
A few weeks ago my motherboard died. So I got a new one and installed it. I also reformatted my hard drive and installed Windows XP from the original Dell cd.
The next step was installing drivers. I downloaded the needed drivers from Dell's site but once I got the Nvidia driver installed, the screen turned corrupted. The pixels went off and looked like they were in the wrong places. The icons seemed as if the pixels were diagonally stretched or something. Text became unreadable.
This happened DURING the installation of the drive. So it wanted to restart after the installation (the screen still looking really awful) and I allowed it. After the reboot the screen turned black instead of opening the log-on screen. So I reloaded last good configuration and all was well again. (It took me back to the state where the Nvidia driver had yet not been installed.)
So I messed around and googled about it and found no answers. I tried deleting all the remaining traces of the previous driver and tried again but it ended the same way. So I booted into safe mode and again removed all traces of the previous drivers. (Using Driver Sweeper and regedit via instructions from forums.)
Then I booted normally and let windows find the VGA controller (uninstalled graphics chip). It ended up installing it as Nvidia GeForce Go 7300. (?)
The weirdest thing was that nothing happened to the screen. So I rebooted and to my astonishment it used the 1440x900 resolution and the screen was clear. But to my great disappointment it turned corrupt again in one to two minutes. A bit later the screen went black.
The next restart the screen stayed clear for longer. I waited a bit and it turned corrupt again. This time though, the screen never blacked out and I was able to navigate to Control Panel where I started the Nvidia control center/panel. But then the screen blacked out again.
After restarting a few times I found out the problem was caused by the Nvidia software. So I ran msconfig and disabled the Nvidia startup processes so that the Nvidia control panel woudn't start at start up. (I disabled NvCpl and NvMcTray, assuming that these indeed were Nvidia processes.)
Next time I restarted nothing happened, the screen was clear and in high resolution. So i decided to check the Nvidia control panel and the screen went corrupt and soon blacked out.
So the last time I restarted I did not run Nvidia control panel and nothing happened. Then I decided to check if everything else works and it does. I tried running some videos in Youtube to make sure it's using the driver version and it managed to do it without problems. Everything indicates that the display adapter is actually working.
So my problem is the driver. Why can't I install my NVS 110m driver? (It corrupted the screen 5 time in a row.)
What's wrong with the Nvidia control panel?
If anyone knows a solution or has run into anything similar, pleas let me know. I'm really trying to get rid of this annoyance that Nvidia has created, so all help is really appreciated.
Till then I'll just try to manage with the current setup.
PS. Just to let you know, I've also checked my laptop screen. My sister has a d630 and I swapped the monitors without any effect. Mine worked on the d630 and the other one became corrupt on mine. So the problem can't be with the screen itslef.
Notebook: Dell Latitude d620
OS: Windows XP 32bit
GPU: Nvidia NVS 110M / installed as Nvidia GeForce Go 7300
Regards,
Van R
Regards,
Van R
