Screen saver not starting?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I have configured the screen saver on my Windows XP Pro to start after 10
minutes. The machine is a member of a domain, but I don't think there is a
screen saver policy in effect. The problem is that recently the screen saver
does not start no matter how long my machine has been idle. It used to work
before.
I have looked at some KB articles, but haven't found any that resolves my
problem.
Any ideas on how to fix / troubleshoot this?
Olav
>before.
Some application running in the background may prevent Windows from
seeing this machine as idle. Check, if these texts can help you find
out, whar software this is:
"How to Troubleshoot By Using the Msconfig Utility in Windows XP"
(http://support.microsoft.com/?kbid=310560)
"How to Perform a Clean Boot in Windows XP"
(http://support.microsoft.com/?kbid=310353)
(tm)
I would really hope that a could have a screen saver kick-in even if the
machine is NOT idle. I would like the screen saver to kick in when there
isn't a USER interacting with the machine (console) for X minutes.
Background programs should be able to run without affecting the screen
saver.
Olav
"Thorsten Matzner" <tmatzner@gmx.net> wrote in message
news:uYwtbCD9EHA.3476@TK2MSFTNGP15.phx.gbl...
>>saver
>>work
>>before.
> (tm)
>saver.
Depends. If the software makes Windows think that a user is
interacting, the screen saver will not start...
(tm)
