Question SD Mini Cards help
itsame
29
I have several Mini SD cards full of various things. I can access the content from the cards just fine, but they ALL say they are write protected. I cannot move/delete/rename files, format the card, none of the CMD prompts do anything.
Still, I can put these cards in ANY device and access the content with no problem. The problem is, I have backed up ALL of this data, and would like to use the cards for something else.
I have no lock switches on my adapters, and I can plug just the cards into my computer anyway, so the solution definitely isn't that simple.
Any suggestions?
Any suggestions?
There might be a lock switch on cards themselves.
Flash devices sometimes become read-only when they run out of spare blocks.
You could try to identify the controller and NAND using a tool such as Chip Genius, and then low level format the card with the corresponding MPTool.
itsame
29
There are 4 cards that were previously effected, and now it seems one I just bought is coming up RAW after having used it yesterday
