fzabkar :
SeaTools is a pass-or-fail diagnostic. It will not fail a drive until a critical SMART attribute falls below its threshold. Speccy, OTOH, will warn you that something is bad long before the drive fails.
You need to examine the raw values of each attribute, especially the reallocated, pending, and uncorrectable sectors.
Could we see Speccy's SMART report?
Ah okay, sure here it is
S.M.A.R.T
Status warning
Temperature 26 °C
Temperature Range OK (less than 50 °C)
01 Read Error Rate 079 (063) Data 00051A46A8
03 Spin-Up Time 095 (083) Data 0000000000
04 Start/Stop Count 100 (100) Data 000000018A
05 Reallocated Sectors Count 094 (094) Data 0000000105
07 Seek Error Rate 083 (060) Data 000D663591
09 Power-On Hours (POH) 078 (078) Data 0000004C50
0A Spin Retry Count 100 (100) Data 0000000000
0C Device Power Cycle Count 100 (100) Data 0000000195
B4 Reserved Block Count 100 (100) Data 0043C58B27
B8 End-to-End error / IOEDC 100 (100) Data 0000000000
BB Reported Uncorrectable Errors 100 (100) Data 0000000000
BC Command Timeout 100 (099) Data 0000000001
BD High Fly Writes (WDC) 100 (100) Data 0000000000
BE Temperature Difference from 100 074 (060) Data 001A18001A
BF G-sense error rate 100 (100) Data 0000000000
C0 Power-off Retract Count 100 (100) Data 000000001D
C1 Load/Unload Cycle Count 100 (100) Data 0000000197
C2 Temperature 026 (040) Data 000000001A
C3 Hardware ECC Recovered 049 (026) Data 00051A46A8
C4 Reallocation Event Count 094 (094) Data 0000000105
C5 Current Pending Sector Count 100 (100) Data 0000000000
C6 Uncorrectable Sector Count 100 (100) Data 0000000000
C7 UltraDMA CRC Error Count 200 (200) Data 0000000000
Appreciate the help
