Question Second M2 ssd problem on tuf b450 plus II
Oct 12, 2022
4
Hi guys
My pc is shutdown and restarting in beginning 4-5 seconds, since i install second M2 ssd to mobo. When i remove second ssd every thing is normal.
So i try to understand problem, i remove second new ssd and install my old (good working) ssd to second M2 slot ( This time mobo has only one ssd and my old ssd). Problem is continuing.
Please help me , thanks
Can you please mention the make and models of your SSD's? What BIOS version are you currently on for your motherboard? Processor that's paired with your motherboard?
Thanks Lutfij
My motherboard is Asus Tuf gaming b450 plus II
İ'm using newest Bios version(3802) and
Processor: ryzen 5 5600x
Ram: 2*8gb ddr4 3200mhz
Old ssd: xpg sx8100 512gb m2 nvme
New ssd: Samsung ssd 980 1tb m2 nvme
On second thoughts, please pass on the specs to your build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
include the age of the PSU as well.
You are on the latest BIOS version for your board. Is the OS residing on only one SSD?
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Sorry, İ'm rewriting my build specs
CPU: Ryzen 5 5600x
Motherboard: Asus Tuf Gaming B450 plus II
Ram: Silicon Power XPower Turbine SP008GXLZU320BSA 2*8gb
SSD/HDD: Xpg sx8100 512gb
Samsung ssd 980 1tb
GPU: Asus Tuf Rtx 3060ti oc v2 8gb
PSU: Asus Rog strix 650b 80+ 650w (1 year)
Chassis: Asus Tuf gaming GT 501
OS: Windows 10 pro
And, yes my Windows Os is install in my old Xpg ssd. New ssd is empty
1 x M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)*
1 x M.2_2 slot (Key M), type 2242/2260/2280 (supports PCIe 2.0 x4 mode)**
*M.2_1 shares bandwidth with SATA6G_56. When M.2_1 is populated, SATA6G_56 will be disabled.
**When M.2_2 is occupied, PCIe x16_2, PCIe x1_1, and PCIe x1_2 will be disabled
Can you state which slots are populated with which drive? One of your M.2 slots operate at (PCIE 2.0 x4)(per the motherboard specs page+the manual), so in that regards, you should've gotten a 2.5" SSD instead of the Samsung 980 as it'd be running at PCIe 2x4 speeds, if the other slot was functional that is.
Reactions: Prenssible
İ understand that in this case, i can't use Samsung 980 in my M.2_2 port because it's PCIe 3.0x4 ssd.
So that when i try to install my old PCIe 3.0x4 ssd to M.2_2 slot my problem continuing.
İf i install PCI 2.0x4 M2 ssd, i can run my system normally
Latest posts
