Hi everyone, let me first say that I have looked in countless forums for this, but I have ben unable to find the answer. I thank you in advance for any help you can offer. I will list my problem first, and then list what I have tried to rectify the problem, all to no avail :-(
Here goes...
I was syncing my iPod, when I hit a glitch, and my system crashed, making it unable to reboot. After being able to rescue a few files, I found that I would have to reformat & reinstall Windows XP. For the most part, things went well, but I have had a few issues with the system now. A minor one that I can deal with is that my system will no longer shut down automatically. The power button doesn't work anymore, so I have to flip the switch on the back of the computer. I have tried both enabling and disabling ACPI in the BIOS, but it doesn't work either way. A pain, but not a big deal.
My main issue that is driving me nuts is that Windows XP will not recognize my secondary IDE devices. They are recognized perfectly in the BIOS, so I know that they are not faulty. They were originally set to master & slave, but now they are set to cable select. They will not recognize in either My Computer or Device Manager. The secondary channel is listed in Device Manager, and is listed as working properly, but no devices are listed under it. I would really like to get everything up and running, because everything was recognized before my system crashed.
Listed below are the things I have tried to fix it, but none of it has worked...
- Uninstalled and reinstalled IDE drivers
- Updated SIS drivers
- Unplugged all USB devices
- Uninstalled and reinstalled from safe mode
- Reset the CMOS and let items redetect
- Unplugged and replugged the CD-Rom and 20 gig HD on the secondary IDE channel
- Disabled and re-enabled DMA modes
- Eaten 2 pieces of pizza
Anyway, none of this has worked, and I don't want to have to reinstall everything in hopes that XP will recognize everyhting from a fresh install. If anyone can help me here, I would be extremely grateful. Thanks again in advance!!
Windows XP
Athlon XP +2400
GeForce 440 MX AGP
SoundBlaster 128 PCI
I/O Magic Video Capture PCI
K7S5A rev. 3.1 mobo
512 MB DDR
Here goes...
Windows XP
Athlon XP +2400
GeForce 440 MX AGP
K7S5A rev. 3.1 mobo
512 MB DDR
