Couple of details I wish to mention first. I'm pretty much disabled and haven't been employed for a long time. The last time I bothered messing with upgrades was in 2018, and a GPU and RAM upgrade happened to be all I needed. Now I'm kind of hoping I can find a suitable solution for my problem as upgrading to a modern PC simply is not an option.
I sincerely appreciate anyone taking the time to bother to read this, as I am well aware of what a nuisance this particular problem is. And even though I'm largely ignorant when it comes to PC components, I know enough about the issue to paint a decent picture.
-- The cooler I am seeking must be compatible with a stock motherboard from a Dell Inspiron 570 PC with an AMD Phenom II X4 965 Black Edition Quad-Core Socket AM3 CPU - apparently the highest CPU I can shoot for. It seems the processor requires a cooler that can handle 125W. Also, the cooler cannot exceed 5.5 inches in height.
-- The motherboard - model 04GJJT - has Intel LGA775 screw type mounting sockets. It should also be noted that modifying the backplate to accomodate a cooler really isn't an option.
I have followed an extensive guide covering various upgrades to the Inspiron 570...
https://www.dell.com/community/en/c...cluding-overclocking/647f2ee0f4ccf8a8de4a0d6b
...and in this guide, it is stated that a specific cooler just so happens to be perfectly compatible with the 04GJJT motherboard - a DeepCool IceEdge 400XT Heatsink. The problem is, too much time has passed and the cooler is nowhere to be found. Fully aware this is my own fault. Really hoping there might be a similar cooling option that is compatible with the screw type mounting sockets.
There is another important note from the guide.
"The Inspiron 570 motherboard lacks software fan control, which can cause issues when upgrading to higher TDP processors like the Phenom II X4 965 BE. Hardware control options for fan speed include fan panel controllers, fans with built-in controllers, or running fans at maximum speed by bypassing motherboard control."
Leaving a fan on constantly is hardly ideal, but it appears to be my only option. I have no space to add a fan panel controller and I don't intend to leave the inside of the case easily accessible.
...I understand this is a major pain. And if this fails, I'll go back to putting up with what I've got. But I'm really hoping I can get some help with this. I just don't trust myself enough to locate a suitable option.
