Question Seeking best 27" 1440p monitor
us0110
44
5
18,535
1. What Is Your Country Of Origin?
Europe, Latvia, Riga
2. What do you plan to do with this monitor?
Primarily gaming, a lot of video and movie watching, using generative A.I.
3. What resolution and screen size do you want?
27" 2560x1440p
4. What refresh rate do you want?
Minimum 144hz, Ideally 240hz
5. How much are you looking to spend? 500€
6. Brands Preferred:
I have no preferance. I like whichever is best.
7. Brands Not Preferred:
None
8. Are You Buying More Than One Monitor?
No
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable?
Should have the latest drivers installed. The GPU has 2 HDMI ports and 2 Display ports.
10. What Port Do You Want To Connect To:
Display Port
11. Is This Monitor A Primary Display Or A Secondary Display?
Primary display to replace my old Zowie Benq XL2411
12. Is This A Secondary Display For A Laptop?
No.
13. Preferred websites for purchase:
Dateks.lv
Balticdata.lv
Euronics.lv
I use salidzini.lv to compare prices
Am currently thinking of buying Philips 27M1F5500P/00
Most shops seem to have it from 420€ to 520€
Those monitors seem similar to the philips one, but they have lower refresh rate, same contrast, lower brightness, lower HDR, and overall seem a little worse.
Or do they have some other features that I am missing?
I spotted that one, but I am not familiar with their review process to gain much from it. A lot of subjective opinion on top of the measured results.
That is just marketing terms for actual technology from LG. Apparently that applies to one of their filter layers blocking out non-RGB wavelengths. Probably just a vapor deposited carbon layer or something, with nano describing the size of the particles.
Some of the anecdotes I tracked down mention the backlight bleed, which the reviewers also mention. That is something I have on my current monitor and would personally avoid. I would just say try to avoid noticing it, because once you do, you will see it.
And a few other mentions that the excess color saturation means that only in certain modes does it have great contrast. So in the most tested mode in that review at 6500K they found the contrast rather low, but the colors accurate. And to get the low contrast you end up running one of the cooler color modes.
Reactions: us0110
The more I learn the more I realize my how much I don't know.
Is it worth it to spend upwards of 700€ for an OLED monitor?
They look superior, but the burn in sounds concerning.
I am leaning towards an OLED panel, but I know I like to run minimal brightness and expect a low duty cycle in a relatively easy to control lighting environment.
If you have a particularly bright room, that means you are going to have to have the brightness up all the time, which means it might only last a few years before showing signs of aging. Really depends how many hours a day you use it.
Latest posts
