I'm needing to know if this can be done or if a SonicWall will work with this type of setup. I have a friend who has DSL service from AT&T (it's the best provider in our town of all options), but they have a Motorola gateway device. From everything I've seen, I should be able to bridge the motorola, but it's kind of a funky way of doing it in that it involves setting the VPN passthrough and using a private static ip for a wan IP on the device sitting behind that gateway device.
What I'm wondering is can you setup a SonicWall's wan ip as a private class on a different subnet than ip that would be used for the gateway? As far as I've seen, it's the only way to get this thing bridged so you can truly pass through to a router/firewall.
The device is a motorola nvg510. I was looking at a SonicWall TZ105.
Thanks!
C.
Thanks!
C.
