Shadwo no longer work with WixXP SP2
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hello!!
We do remote control to our WinXP SP1 computers shadowing the console
session with the following command:
shadow 0 /server:hostip (from a remote desktop session)
We no longer can remote control computers with WinXP SP2 installed, we get
an "acces denied" error.
Any idea?
Regards,
Christian
> we get an "acces denied" error.
First - I did not know you could shadow remote local sessions on Windows XP
at all.
Second - have you configured the "automatically on" firewall appropriately
to allow such traffic?
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
Hi Shenan,
Yes that's possible (see references below).
I don't know the "automatically on" feature in the firewall. How do I set
it? (I manually disabled the firewall from the panel control to discard this
kind of issues).
Regards,
Christian
http://groups.google.com/groups?q=%22shadow+0+/server:%22&hl=es&lr=&selm=rslikv48b7b4bkfu2buooohutbpfsdb79h%404ax.com&rnum=1
http://ask.slashdot.org/comments.pl?sid=126314&cid=10574052
"Shenan Stanley" <news_helper@hushmail.com> escribió en el mensaje
news:ecf8aCyyEHA.3908@TK2MSFTNGP12.phx.gbl...
XP
> at all.
> <- Shenan ->
You need to enable the Remote Desktop exception in the Windows
Firewall...
Jeffrey Randow (Windows Networking MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows Network Technology Community -
http://www.microsoft.com/windowsserver2003/community/centers/networking/default.mspx
Windows Home Networking Community -
http://www.microsoft.com/windowsxp/expertzone/communities/wireless.mspx
On Mon, 15 Nov 2004 10:59:55 -0300, "Camacho, Christian"
<chris@na.com> wrote:
>Hello!!
>Any idea?
>Regards,
>Christian
Hi Jeffrey,
Yes, we did enable that exception (TCP 3389 port), we also disabled the
firewall.
We can connect to the computer using remote desktop client, but we no longer
connect to the same computer using the shadow command (from a remote desktop
session in a different computer).
Regards,
Christian
"Jeffrey Randow (MVP)" <jeffreyr-support@remotenetworktechnology.com>
escribió en el mensaje news:5quip05ov0j01qrrv89bovgvjk9vre07v3@4ax.com...
> Firewall...
> >Hello!!
get
> >Any idea?
> >Regards,
> >Christian
OK... Lets try a test...
Are you able to get to the Computer Management console of the remote
computer (by running compmgmt.msc and then select the Connect To
Remote Computer option)? I have found that you will not be able to
use the shadow functionality if you can't connect to the Computer
Management console...
On Tue, 16 Nov 2004 14:00:14 -0300, "Camacho, Christian"
>Hi Jeffrey,
>firewall.
>Regards,
>Christian
>> Firewall...
>> >Hello!!
>get
>> >Any idea?
>> >Regards,
>> >Christian
Hi,
The solution is to add a value in the registry:
Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server
Value Name: AllowRemoteRPC
Value Type: DWORD Value
Value Data: 1
Regards,
Christian
"Camacho, Christian" <chris@na.com> escribió en el mensaje
news:e7U59z$yEHA.1400@TK2MSFTNGP11.phx.gbl...
> Hi Jeffrey,
> firewall.
> longer
> desktop
> Regards,
> Christian
>> Firewall...
>> >Hello!!
> get
>> >Any idea?
>> >Regards,
>> >Christian
