Hi,
I have a pretty standard setup with 3 (120mm) intake fans at the front and one rear exhaust fan, the case is Phanteks p400a.
I have i9 10900k with noctua NH-U12A cooler and the idle cpu temps are very good, around 26-30c depending on the room temp (usually 21-24c with air conditioner).
But on load they jump to 80-90 pretty fast.. and I notice that it takes a few minutes for the cpu to return to its original (30'ish) temps when the load is over.. I wonder if that's because the single rear fan isn't capable of exhausting the hot air fast enough.
I also want to know, with a straight front to back air path like I have, what is exactly the logic of adding a top exhaust fan, I mean..the cpu cooler is pushing the air towards the rear fan pretty aggressively, so by adding a top exhaust fan, wouldn't it be "disrupting" the air direction?
Thx.
Thx.
