Question Should i enable/disable any of these bios settings to increase stability during CPU overclocking? also which power plan is optimum for same reason?
eziowar
419
14
18,795
Hi, my cpu i5-4670k,cpu cooler-Hyper 212X , gpu - Asrock rx 7800xt challenger oc, mobo- gigabyte z87x-ud3h, bios version F10b, psu corsair cs650m, corsair ram 4x4gb @1600 mhz dual channel, Crucia MX 500 500gb ssd,windows10.
View: https://i.imgur.com/JKE3xed.png
View: https://i.imgur.com/Pw3ppw6.png
If you are trying to get get every bit of performance from your cpu use the high-performance setting in Windows. As far as bios settings the ones I would change would be to turn off C1E, C3, C6/7 these are power saving setting. Also turn off Eist it changes your cpu voltage and core frequency if you leave it on.
Reactions: eziowar
bad advice, the cpu will always at max clock and voltage, VOLTAGE. This isn't good, it need a rest and run at max when need. All these setting is for cpu efficent if you overclock or not. it auto boost to max clock on demand
Reactions: eziowar
