Radeuz Aug 31, 2021 1 0 10 Aug 31, 2021 #1 You can see fan setup in case. Is top right exhaust fan pulling fresh air coming from front top fan? Should i remove it soo CPU cooler can pull more air?
Solution kerberos_20 Aug 31, 2021 if you put hand above it, do you feel hot air or cold air? if its cold, then you can turn it off
kerberos_20 Champion Dec 24, 2011 9,921 1,593 55,740 Aug 31, 2021 Solution #2 if you put hand above it, do you feel hot air or cold air? if its cold, then you can turn it off Upvote 0 Downvote Solution
