Zalman CPNS9700LED on a Q9550 with Noctua NT-H1 Thermal Compound.
The temperature difference of 5 degrees always seems to be there, is this normal? I would be happier if all the core temperatures were similar.
Perhaps one half of the CPU does not have good contact with the heatsink?
Anyway you'd best re-apply it with a thin line of even paste since Noctua NT-H1 is some good stuff and you shouldn't have that big temperature difference if it was on there evenly. I make sure to put a thin layer across the bottom of the heat sink to ensure better heat transfer.
