[SOLVED] Should i submerge my hard-drive in my mineral oil pc?
Feb 28, 2019
23
So i have buildt a pc that is submerged in mineral oil. Since the hardrive (2tb seagate hdd) makes quite a lot noice can i submerge it in mineral oil with all the other parts?
Probably not since had drives use delicate moving components and mineral oil could damage them. You could probably submerge an SSD in it if you wanted.
Absolutely not.
That dive is NOT sealed. There is a small vent hole (pressure equalization), with a little filter pad thing.
The oil WILL seep into the drive innards, killing it.
Do not do this.
Reactions: Antonpa
