Hi, so this is my system:
CPU: Ryzen 5 1600 @3.7 GHz
Motherboard: MSI B350 Gaming Plus
Memory: Corsair Vengeance LPX 16 GB (2x8 GB) DDR4-2666 MHz OC to 3000 MHz
Storage: WD Blue 1 TB and WD Green 2.5" 240 GB SSD
Video Card: Zotac GTX 1060 6 GB(not sure if it's AMP Edition or not)
Power Supply: Corsair CX550
Case: Cooler Master Lite 5
Right now, I have an Asus VP228H, which is a 1080p 60 Hz panel, although it tears at 60 Hz refresh rate and runs better at 59 Hz(don't know if that's normal, still kind of a noob about monitors). My question is, with these specs, should I upgrade to a Freesync monitor with DisplayPort to use the Gsync feature? I'm on a budget so I will go for lower end options like AOC G2460VQ6 or LG 24MP59G, neither of which is on the official Nvidia list but I hope they'll work anyway.
The real catch here is that I recently built this PC, and it is a very major upgrade from the previous PC, which could barely play Half-Life 2 at 720p 30 FPS, and now I can play everything at 1080p 60 FPS, which feels pretty smooth to me comparatively. So my real question is, will upgrading to G-Sync be worth it for me? Because at the moment 60 FPS feels pretty good to me, but the thing is I haven't played newer games yet, I'm still finishing off older games that I couldn't play on my older PC, so I don't know if my GPU will give me such smooth performance on the newer games. I know the 1060 is a capable card, but does G-Sync help a lot in newer games?
Hopefully this isn't too confusing, and also in the right place.
