Should i use liquid cooling when using a Amd 9370FX
Get Cpu
4
Hello can anyone help me I've been looking around forums and websites and people recommend using liquid cooling.I'm on a budget and if not necessary I would like to use the 9370 without liquid cooling if you have to use liquid cooling can anyone recommend and am3+ CPU under £200 because liquid cooling is expensive and as I said I'm on a budget
Any respone would be appreciated
Get an 8320 or 8350. Stay away from the 9xxx series. Yes, you need water cooling with them. They run hot. Very hot. They are also only compatible with a few different motherboard that can put out the power and deal with the heat they put out.
ok thank you for your support and tips much appreciated and yes I've been looking at the 8350 but i was just wondering if it required liquid cooling and it does so I will buy the 8350 Thanks :)
Ok will do thanks although my CPU cooler is the Alpine 64 PRO Rev.2
