heres a question, which placement of fan is better? the rear or the side?
Side fan - Stand right parallel to the CPU, allowing the heat to quickly leave the computer, although the fan is'nt at the top most side of the case, so some heat still may remain at the top most area, as heat rises up
Rear fan - These fan(s) are located at the rear of the computer, most likely at the up most top and right next to the CPU, allowing cool air to enter from the front fans and out the rear fans allows easy cooling, although it might not be as effective as the side fan since the side fan is much larger 200mm, compared to the 120mm fans, which makes much more heat dissipate from the CPU as the side fan stands right over it
Some exampls, a Cooler master and an Antec 1200, sorry for no links, i usually dont chekc out cooler masters but i know some of their brands have a side fan
