News Silicon Motion Demos PCIe 5.0 SSD Controller Up to 13.6 GBps
Couple Thoughts
  • To those only wanting to buy a Mobo that has M.2 PCIE gen 5 support, you may get a drive mid next year to utilize it.
  • Sure Wish Optane was still around to release a P6800x to own this space, sad
  • what we really need to see is minimum sustained write speeds, most drives blow as soon as you run out of cache(40-400MB/s). For sustained metrics this is what matters not the initial burst.
    • Passmark only writes 800MB in its test, user benchmark only does 90GB... With how large some of the SLC cache seems like it should be dynamic based on total drive size, say last 3% of fill during a 1/4 drive fill.
"Silicon Motion's MonTitan SM8366 SSD platform (opens in new tab) is designed primarily for enterprise-grade SSDs. It features 16 NAND flash channels with a 2400 MTps ONFI/Toggle interface to connect up to 128TB of 3D TLC, 3D QLC, or XL-Flash memory. The controller supports DDR4-3200 and DDR5-4800 DRAM buffers with a dual-channel interface and a PCIe 5.0 x4 interface or dual independent x2/x2 or x1/x1 interfaces to connect to host (s). "
Enterprise grade SSDs usually have another significant feature which is hot-swap-able, that's why they usually come with U.2 (support hot-swap) instead of M.2 (does not support hot-swap).
