Review Silicon Motion SM2508 SSD review: Finally, a true PCIe 5.0 contender
What this makes me wonder is when we will finally get an 8TB QLC drive just running in 2TB SLC mode permanently. No caching. Just pure speed all the time.
I would love to dream about an actual SLC drive, but I know that won't happen. TLC or QLC running in full-time SLC mode will probably be the best we will ever get.
Already exists. LX3030 is one example. I don't think that combo panned out much. There were also some Chia drives planned with that but didn't pan out, and some E18's for Plotripper with BiCS TLC. pSLC drives exist as industrial/commercial options, and in some cases you can manually convert (my one discord mod has done videos on this). "Real" SLC is gone as even the low latency specialist flash is basically 2-bit MLC at this point. There are ways to simulate the advantages of SLC (e.g. smaller, more plentiful planes) with X-NAND but haven't seen it used yet and certainly not consumer.
There is finally an incentive for AMD to add PCIe 5.0 to their mobile chips.
Even LNL features a paltry 4 lanes of PCIe5.0
I think controllers like the E31T, SM2504XT, and the MAP1802 would be better for mobile. Samsung also has 5nm tech for x2 Gen5 (not great results on the 990 EVO). Eight-channel with DRAM still draws too much, although SMI's implementation may in some ways be more power-hungry than you could get away with if you tried. But they do seem to have worked on power management, would be interesting to see how it works in mobile.
Reactions: JarredWaltonGPU
This looks like a promising improvement over existing products. I'm looking for something that doesn't use Phison’s E26 after killing two TeamGroup Z540 SSDs with stress tests.
Reactions: Maxxify
Do you think that it is possible to make good drive with 50-100 P/E cycles of endurance and devoting most of drive to fix dying like soap bubbles memory cells ? You think your OS will continue to boot and apps will be responsive on the drive consisting from dead holes like Swiss cheese?
QLC is planned obsolescence and nothing else.
