Silverstone PWM fan hub question
suburban_ninja
Commendable
Apr 18, 2016
I am putting my components in a new case with more airflow, its this one
http://www.amazon.com/Corsair-Carbide-Series-SPEC-02-CC-9011051-WW/dp/B00I0MKMG2?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00.
And I will be running its off this
http://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?ie=UTF8&qid=1461033950&sr=8-1&keywords=fan+hub
because my mobo only has 3 fan headers. The cpu and 2 chassis headers. I plan on running 6 of these
http://www.newegg.com/Product/Product.aspx?Item=9SIA1K633D0197&cm_re=af120-_-9SIA1K633D0197-_-Product
My question is basically the best way to hook this up. Is it ok to run these fans at 12v at all times. They are not pwm fans so I planned on leaving my cpu cooler plugged in the cpu header and plugging the 6 case fans in the hub and plugging the hub in a chassis header and the hub power to the sata power cable that comes off the hub. Thanks in advance.
Yes, you can run your fans at full speed all the time. It will shorten their life a bit compared to slower operations, but you already know and accept that. You are correct about the power source.
If you plan to get a manual third-party fan controller also, that changes the picture to one of two choices.
1. Forget the Silverstone Hub. Just buy a fan controller with many outputs, enough to connect all your fans. It could be by a controller with six outputs, OR one with fewer outputs plus a few 3-pin fan Y-splitters. The splitter allows you to connect 2 fans to one controller output port, and I'm sure the controller's ports can handle up to 2 fans per port. Just be sure that the controller you buy has output connectors that are the same...
You did not tell us an important thing - exactly what mobo you are getting.
That Silverstone fan hub is specifically for use with a true 4-pin mobo header that is operating in PWM Mode, AND with 4-pin fans.
You say you plan to use 3-pin fans. If you do that, all of those fans will run at full speed all the time. A 4-pin header or a 4-pin fan hub like this can NOT control the speed of 3-pin fans! If you want to run all your fans at full speed all the time, all you really need to do is use adapters to connect them all to a PSU power output - you don't even need to connect anything to a mobo header that can't control them anyway.
HOWEVER, if you actually expect your mobo to control the speed of all those fans, you MUST buy 4-pin fans. You also need to be sure that the mobo SYS_FAN header you plug the hub into does really use PWM Mode. (There are some mobos that have "fake" 4-pin headers that actually operate as 3-pin headers in Voltage Control Mode with a useless 4th pin.) That is why I asked for the exact mobo you are getting, so we can check its manual for details.
I suggest you get 4-pin fans all around and use the Silverstone hub to connect all the case ventilation fans to one SYS_FAN header for control. Then separately you connect your CPU cooler to the mobo CPU_FAN header so it can be controlled properly by the CPU's internal temperature.
I know they will not be able to be controlled. I was basically asking if they are ok to run on 12v at all times. I know that will lessen the life and they will be louder. And I thought since the hub was powered off sata that it wouldn't work the mobo header to hard and fry it. I just wanted to make sure it's fine to run like that. I plan on getting a fan controller to adjust it manually by voltage on the dial. Thanks
1. Forget the Silverstone Hub. Just buy a fan controller with many outputs, enough to connect all your fans. It could be by a controller with six outputs, OR one with fewer outputs plus a few 3-pin fan Y-splitters. The splitter allows you to connect 2 fans to one controller output port, and I'm sure the controller's ports can handle up to 2 fans per port. Just be sure that the controller you buy has output connectors that are the same as the "normal" 3-pin ports on a mobo, and not some special type of connector. IMPORTANT: since you will be using only 3-pin fans, you MUST get a controller for 3-pin fans in Voltage Control Mode. A controller with true 4-pin outputs using PWM Mode can't do the job.
2. If you really want to use the Silverstone Hub AND control them as a group using a manual third-party controller, you MUST instead buy a controller that DOES use true 4-pin output in PWM Mode so that the Hub gets a PWM signal to use. MOREOVER, that Hub still cannot control 3-pin fans according to what your manual controller sends it. Your fans will HAVE to be 4-pin fans to give you control using a 4-pin PWM Hub.
Thanks doc. As I already have the hub, gave to me by a friend, I'm going to run it until I can get a controller. Thanks for the info on everything, nice to see a helpful community. So I guess I'll be on the hunt for a nice 3 pin voltage controlled fan controller. Thanks!
