G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I've got an old computer I bought for under a hundred dollars. It
was a business computer. It has an Asus board and an Asuki box. My
front fan is noisy, but it looks to me that to replace it, I will
have to cut the wires. Is this normal?
The wires from the fan lead to a plug that was stuck behind the
motherboard. When I pulled it out and looked closely at it, it
looks as if the wires from the fan are joined to other wires by
brass clips that are crimped on, holding the two sets of wires
together. The wires are soldered on at the fan end.
I'm thinking of just cutting the fan wires, and killing the fan
entirely, without replacing it. The CPU has got its own fan, and
so does the power supply. The CPU is only 400 MHz, so it doesn't
need much cooling. If I just cut the wires, will I get an error
message? Will it screw up anything?
