Hello.
I want to know if I can use the iGPU of i5 6500 with a vga monitor.
My budget is tight so I will upgrade the monitor and buy gpu later on.
The mobo is Asrock B150M Pro4 and has a D-sub (VGA) port. Also using the iGPU for browsing and gaming (dota2,csgo) will this require a aftermarket cooler or should I stick with the stock one?
