Hey. folks
It is so that I sit with a
- Gigabyte GA - Z68MA - D2H -B3 ( v.1.3 ) with SLI support ( 8x / 8x)
http://www.gigabyte.us/products/product-page.aspx?pid=3855#ov
- 2 x GTX 780 ( ZOTAC OC + EVGA SC ACX 2.0)
http://www.evga.com/Products/Specs/GPU.aspx?pn=C811FD6B-7E4F-4C02-9839-9C581D7B338C
http://www.zotac.com/products/graphics-cards/geforce-700-series/gtx-780/product/gtx-780/detail/geforce-gtx-780-oc/sort/starttime/order/DESC/amount/10/section/specifications.html
The problem folks are:
when I insert Zotac cards into the x16 lane and EVGA card into the the X8, the computer finds them properly and SLI can be enabled however every time when a game or a 3D application tries to run in SLI mode the screens blackens this also happened when I tried to turn on 3D marks , but Here's the strange thing that puzzles me:
if I change places between them the computer can not longer find the card in the x8 lane, and SLI of course cannot be enabled. And this I really cannot comprehend, what the dilemma is? Would really appreciate if you give advice or tips for this.
Remaining . specs . if needed
- I7 3770 + CM : Nepton 140XL
- 8 GB DDR3
- Fractal Node 804
- LEPA G1000 -MB (1000w)
http://www.tweaktown.com/reviews/4977/lepa_g1000_ma_1000_watt_80_plus_gold_power_supply_review/index.html
- 8 GB DDR3
- Fractal Node 804
