Archived from groups: comp.sys.ibm.pc.hardware.storage (
More info?)
On 3 Jan 2005 23:59:56 GMT, Arno Wagner <me@privacy.net> wrote:
>Previously puss@purrpurr.com wrote:
>> Yes just has another hard drive fail, I was using Active Smart but some of
>> the results are misleading.
>> the TEC was Jan 2005 its now failed the other drive Seagate 120g, the same
>> model was showing March 2005 not showing Jan 2005
>> The Bar graphs showed the Drives all OK..
>> So is SMART just a big waste of time
>> Also can some one recommend a drive that will last more than 2
>> years, this is my 2 second one to fail, first Seagate failed in 2
>> weeks the other drives that I had were IBM they were replaced with
>> Seagates that I still have but no using.
>I found SMART monitoring is worthwhile on Maxtors, however their
>threshold for an actual failure is far too high. I had one disk
>that was already incredibly slow from having to reallocate unreadable
>sectors all the time, but the smart status was fine. The reallocated
>sector count was already in the hundreds.
>I am now logging and monitoring the realocated sector count and the
>temperature. Smartd also does a nice job of notifying you of any
>change in the more critical attributes.
>Not perfect by any means but a real time-saver so far. SMART allows
>me to replace a disk at the first hint of trouble and give it some
>heavy testing load. So far this resulted in all but one disks in
>a SMART failure within some days.
>One additional consideration: Most of my disks are from Maxtor.
>Thay have a tendency to fail gradually over days or even weeks.
>IBM/Hitachi and WD disks (don't know about others) seem to have
>a tendency to fail fast and catastrophically. SMART monitoring
>will probably help far less in that case.
>Arno
Yes I was using ActiveSMART and these Drives 2 x 120g Seagate's have only been
used for 5 months, the TEC for the other drive is showing Jan 2005..
Problem here is the Have to fail to get a replacement..
What monitoring software are you using..?
The main problem here is the drives are not shipped correctly from the
Importer/Agent or the Mail ordershop..
I know this as the shop that I deal with sent me a Photo of the Maxtor drives
that he received for the Agent, 5 drive loose in a box with a few bubble bags
thrown in fact the drives were showing physical damage.
I also received one drive sent in a Jiffy bag with a bit of bubble rap around
it..
Seagate shows on there web site how to pack a drive for a RMA..
