So Close ... It Won't Fit! Help!!
Once again do not run your system without the heatsink mounted properly. You are doing nothing but hurting your new system. the heatsink will not work correctly unless it is frimly fasten to the motherboard NOT just sitting on top of the cpu.
Why do you post if you will not use the advice of the people here?
earlier you said the hs fell off.
if the copmuter was on it could have fried the cpu.
it can happen in about 2 to 3 seconds.
i mean to say the cpu can catchfire that quick.
thg had a video of them pulling the hs off a cpu
instant smoke :cry:
You're making me bang my head into a wall from fustration. Check when the computer is off by turning the case upright and seeing if the HSF falls off.
Did you remove the motherboard from the case and mount the heat sink and make sure that the plugs went thru the mounting holes and locked?
You keep running the CPU under these conditions and you'll end up on my thread. The Worst PC Screw Ups thread. You don't want that to happen.
Dude you REALLY should of just taken the mobo out and THEN installed the HS/F. Would of saved you time, hassle and possibly the cost of a new HS/F.
When I was a kid -- oh, about age 12 or 13 -- I had a friend that liked to make model airplanes, the same as me. Only, it would take me about a week to painstakingly put one together, paint it and then carefully apply the decals. My friend would put the same model kit together in ONE DAY.
The difference, of course, is that my finished airplane looked just like the picture on the box -- and my friend's looked like crap.
This is a hobby that rewards those who are methodical, careful and precise and punishes those who are impatient, rushed or careless.
Please follow DaSickNinja's advice and take a breather. Take the entire computer apart, then reassemble it SLOWLY and CAREFULLY.
And if you can't get the Scythe HSF to work, remember there is nothing wrong with the stock HSF for that CPU -- assuming you got a retail version and not OEM. At this point it might be worth it just to use the stock HSF to save yourself some aggravation.
Oh, one more piece of advice. Check the packaging that came with the Scythe HSF. There should be aparts list, preferably an illustration showing all the parts and how they go together.
Did you install everything? Are you sure you only used the right parts for your motherboard's socket? Is that HSF a type that only fits the INtel socket or did it come with parts to also fit an AMD? Did you only use the parts that fit the INtel socket?
Does that HSF require a special backplate that fits on the back of the motherboard? Did you install that backplate before trying to mount the heat sink fan? If that HSF has parts for both AMD and Intel, are you sure you used the Intel backplate and not the AMD one?
If you still have the boxed HSF you can use the mount plugs from that if you've damaged the ones on the Scythe. Just be real careful when removing them with a knife or (flathead) screwdriver.
Crual,
These folks have told you the answer. Many people prebuild their system outside of the case as a just to make sure thing..
The recommendation still stands and you still are not listening.
You asked for help but do not like the proper answer..
These folks are trying to actually save you "time and money"
Please listen to them... This especially:
"DO NOT RUN YOUR PC IN ITS CURRENT CONFIGURATION WHERE THE HSF IS NOT SECURED THE RIGHT WAY!! YES I AM SHOUTING ON PURPOSE"
5$ you end up frying something! the reason: impatience, and not listenning. In a war you would be dead already! 😀
And yeah as mentionned, you would have actually saved some time if you took the mobo appart!
Always setup the cpu and HSF before mouting the mobo!!!
If the HSF seams to be ok, but falls, you probably damaged some of the "connecting pins", inspect them, , the little white part can be bent, also make sur the arrow are pointing outside, rotated 90 degree.
Add this one.... Its already earned a place in your list. Somewhere near the top, I'd think.
We may seem a bit harsh about this, but we can't bear to see a perfectly good C2D burn up without the benifit of overclocking the hell outta it.... and we want to save you money. So please, just listen to what I wrote. Remove the motherboard and then put on the heatsink. You'll give me less heart burn. And make me stop drinking so much coffee.
levicki: crualtortus! No!!! Do not go through the minefield!!! Go around!
crualtortus: omg, i dont want go around! it takes forever. it is anoying as hell!
levicki: Listen to me! You can't survive going through the minefield!!!
crualtortus: I will dash through it, I will pass for su... KABOOM!!!
levicki (shakes head): Tsk, tsk, tsk... young people are so impatient these days.
lol you guys act as if my computer is gonna die. Its working, Im using it right now! And I must say it is amazing. and the heatsink is on correctly. my temp is around 40 idle. not sure if thats good or not. the only computer store around here that sells thermal paste only sells some cheap shit. but besides that, not to bad. I had overclocked it to 2.4, and the the temp under light load was about 45. not sure if thats good or not. you guys should advise me on some overclocking tips or something. im running the memory and voltages on auto cause this is my first time ever. but yeah, just checkin in on you guys to let you know im alright. did i mention the thing is insane? its so fast compared to my other comp that i was loosing it.
You have never seena CPU catch on fire so I would believe you don't know the dangers of an improperly mounted HSF. We just get really twtchy when directions are not followed, especailly with expensive hardware.
Nice to see you rig works. Hope that it brings you much fun and pleasure.
Ninja
thanks all for the help. My computer is so awsome. I can do like 5 different things at once and the computer wont even bog down. its awsome as h3ll
alright you guys. more problems :\ My computer was working fine, I did a couple things, windows update, play games typical user stuff, then shut computer down (it shut down fine); and went to work. came home, turned on computer, and it said read disk error, restart. I tried dinkering around with it and couldnt get it to boot. so I tried reformatting. wouldnt let me. it said that some file or something was fucked and if i reformat something could be damaged. so I tried quick format. everything seemed to be going ok, it was formating and stuff. then when the computer got done with that it rebooted, and some file was missing so it couldnt boot. So I tried reformatting again, this time the long version. it actually was working. it got to 100 percent, sat there for a minute or so, then said that the disk is damaged. so what do I do? i think the hardrive crapped out, but why? i used it like for like 3 days. by the way it a WD2500SD.
.... what... the... hell...
Your best option is to call the manufacturer and RMA the component. I'm not sure how this could have happened but since this is a hard drive problem I do believe that it could be better addressed in a more appropriate portion of the Forumz. Such as here.
Then again someone here could have the quick answer.
And for the grace of God and all things holy, listen to us this time. [/exasperated]
