Say, for a test-bed with a mid-range CPU (65W) and, a GPU with no PCIe connector. Right now, Ryzen 5 1600AF and either a GT 730 or Quadro K600 for GPU.
Disclaimer: It's a 20-pin ATX connector in an HP system, but is plugged into a motherboard that came with that HP from the factory with a 24-pin connector. Is that even something that will work on a modern, current gen motherboard? At the moment, I'm considering sticking a B450M motherboard
Also, stop laughing, I realize it's only 168W on the 12V rail . . but, within that limit, is it safe, or still a dumpster fire?
I absolutely do plan to get a proper PSU before I put in any sort of mid-range or higher GPU, or do anything particularly demanding on it. This is more of a "for the time being, can I install Windows, and do some minor CPU tests" situation.
