TLDR: My PC keeps crashin during games. Don't know if it is a GPU, CPU or RAM issue. I tried everything within my limited knowledge but to no avail
My PC:
CPU: AMD Ryzen 9 7900 (not overclocked)
CPU-Cooler: Bequiet! Dark Rock Pro 4
GPU: ASUS TUF 4090 OC (not overclocked)
MB: ASUS TUF GAMING X670E-PLUS WIFI
RAM: G.Skill Flare X5 32GB DDR5 Kit
PSU: 1200 Watt be quiet! Straight Power 11 Platinum Modular 80+
OS: Windows 11 Pro
Issue:
PC runs stable during tasks like browsing, word processing, and development. However, it crashes during gaming after 2-20 minutes. I've noticed that lowering the graphics settings allows for longer gameplay. The crashes mostly drop me back to Windows, occasionally resulting in different BSOD (e.g., String: IRQL_NOT_LESS_OR_EQUAL, Code: 0x0000000a, Driver: ntoskrnl.exe). Additionally, I've observed recurring errors in the Event Viewer during each restart or normal operation, although they don't manifest during regular use. Examples include:
Here's what I've tried so far:
What else can I do to fix these crashes?
How can I determine which component (CPU, GPU, RAM, power supply, Windows, etc.) is causing the crash?
Thanks for your answers
My PC:
OS: Windows 11 Pro
Issue:
- Error: Source: Firefox - The system cannot find the specified file.
- Error: Source: DistributedCOM - The server "{ }" failed to register within the specified time period with DCOM.
- Error: Source: ServiceControlManager - The "Windows Security Service" service terminated unexpectedly. This has occurred 1 time already. The following corrective action will be taken in 60000 milliseconds: Restart the service.
- Installed the latest drivers (including BIOS and GPU).
- Completely reinstalled Windows 11
- Set RAM to default settings from EXPO 1.
- Ran hardware tests:
- RAM: Memtest86 - 6 passes -> no errors.
- CPU: CineBench -> stable after multiple tests -> no errors.
- SSD: Samsung Magic Health Check -> no errors.
- GPU: FurMark -> stable ->I stopped it myself after approximately 40 minutes.
- GPU: EzBenschmark -> Benchmark crashes at higher settings every 2 or 3 attempt
- GPU: HeavenBenschmark4.0 crashes at higher settings every 2 or 3 attempt-> Exception code 0xc0000005.
- Ran various recommended Windows scans (e.g., sfc /scannow) -> no errors.
- Checked the temperature during stress test → All is fine
