Hello guys, i'm stuggling to find an answer while searching on this forum, so I deciced to post the question here. UPDATE: I have found simular posts with spikes but they lasted only +/- 2 seconds.
I have completed my new PC build witht the 13600KF intel processor. I am cooling the chip with the Cooler Master ML240L RGB v2 water cooler, and my temps on idle are very good (37C).
The problem:
When I am stresstesting the chip on full load, the first 20 seconds are very very hot. (100C with termal trottling). After that (while still under full load) my temps go down instantly to a very nice temp again for this chip (74C max under full load). I have tested Cinebench R23 multiple times with a 10 minute test each. Always the same result.
My question:
Is it normal to have termal trottling for only the first seconds? Does the watercooler need 20 seconds to adjust to the instantly full loading chip? I dont know if those spikes are harmfull to my system. Maybe the sensors have a latency and the cooler is already cooling better then the software shows? Do you guys have simular results?
My waterpump fans are set to always full speed in the bios and are connected to the WP header.
My other fans (push and pull) are set to performance and are connected via a hub to a different fan header.
The programs used for benchmarking / stresstesting are:
First 5 seconds trottling under full load, then normal temps: Blender Render
First 20 seconds trottling under full load, then normal temps DAZ STUDIO NVIDEA IRAY (full 4K render)
First 10 seconds trottling under full load, then normal temps Cinebench R23
Note: in games like PUBG on ultra settings 1080P, there are no spikes because there was no full load.
SEE IMAGES:
MY IDLE TEMPS:
MY FIRST 20 SECONDS FULL LOAD TEMPS:
FULL LOAD TEMPS AFTER SETTLED
MY PC SPECS:
Asrock B760 PRO RS
13600KF
AIO: Cooler Master 240L RGB v2
Corsair Dominators 2 x 8 GB 4000MHZ
ASUS 3060 TI OC
Corsair sp120 elite fans (also used for the water cooler)
Thank you for replying in advance. If you need more info, let me know.
The problem:
My question:
SEE IMAGES:
MY IDLE TEMPS:
MY PC SPECS:
Asrock B760 PRO RS
13600KF
ASUS 3060 TI OC
