To Hell with that! Let's speculate, panic and cuss right now!Reviews are around the corner, and there we can have a better view of how the GPUs behave.
Ah right, that would increase the length of the wire. Makes sense. Seems like that hasnt stopped people from creating such products lol - https://www.amazon.com/Fasgear-PCI-5-0-Extension-Cable/dp/B0B7MGTY56?th=1When you add a adapter you have already added a extra potential fail point, when you add length to the cable you change the resistance lowering the power it can provide.
EDIT and most of the PSU and cable mod companies are selling cables for the cards that plug into the 8 pin PSU side and right into the video card.
Good stuff right here.
View: https://www.youtube.com/watch?v=EvsPZA8CkBY
OK but everything I stated or linked is correct.Ah right, that would increase the length of the wire. Makes sense. Seems like that hasnt stopped people from creating such products lol - https://www.amazon.com/Fasgear-PCI-5-0-Extension-Cable/dp/B0B7MGTY56?th=1
That video was nice BTW. However it doesnt answer 1 question. I believe I came across a link (either wccf or videocardz) where they show current coming from 2 different 8pin PCIe wires were vastly different when they were connected to a 12 pin pcie adapter. Wonder how much damage that would cause. I dont know if that PSU was single or multi rail.
EDIT: There you go - https://videocardz.com/newz/pci-sig...e-with-12vhpwr-pcie-gen5-power-cable-adapters
EDIT 2: Never mind Jonny answers it here in the comments - https://wccftech.com/atx-3-0-12vhpw...r-safety-risk-using-adapter-confirms-pci-sig/
The FE PCB is so small, its hard to put 3 or 4 X 8 pin connectors, hence that 12 Pin move.EDIT I think all these cards are 16 pin for about no reason and most are recommending 3X 8 pin for adapters.
No crap and it's 16 pin for the high end adapters they use either 3 X8 pin or 4X8pin adapters.The FE PCB is so small, its hard to put 3 or 4 X 8 pin connectors, hence that 12 Pin move.
People will buy anything they think looks cool without knowing anything about it's design.Ah right, that would increase the length of the wire. Makes sense. Seems like that hasnt stopped people from creating such products lol - https://www.amazon.com/Fasgear-PCI-5-0-Extension-Cable/dp/B0B7MGTY56?th=1
