[SOLVED] SONY HT-S350 i need buying advice
nano81
14
I need new soundbar and after few hours of research my choice fell on SONY HT-S350 2.1 Wireless Sound Bar.
It costs around 170 pounds and this is maximum im willing to spend.
Now my question - is it a good product in your opinion ? do you think you can buy something better for the same price? The only thing which matters here is sound quality ( i know its just a soundbar but still.. )
I got medium room with 55inch tv , mostly music and Netflix .
I would appreciate any constructive advices, thanks!
I listened to about half dozen or more soundbars, including a Sony (not your exact model though) some higher end stuff.
The one I liked best was a Vizio, this one https://www.vizio.com/home-theater-system/sb3251ne0.html with wireless sub and rear speakers that were wired to the sub. I actually got super lucky and was at a WalMart with them for $180 but someone on craigslist was selling a higher end larger model for $50 LOL
This one sounded nicer with music than the others, both my wife and I liked it better than other soundbars that were double the price.
The sub and rear speakers attached to it are just on the floor behind my couch, sound just fine that way with the low end being less directional so having the sub behind you...
The sub and rear speakers attached to it are just on the floor behind my couch, sound just fine that way with the low end being less directional so having the sub behind you is not that big of a deal, and having the rear speakers is a nice bonus for the price.
Thanks! - I will take your advice into consideration
