G
Guest
Guest
I saw a phew things i like to commend on.
1. clean power is good to have repeatable test, but irl power is never clean, and one thing a good PSU dose is keeping the dirt on the net out.
So i would advise after the Chroma AC Source 6530 put in a device that can generate noise on the AC power source.
(a electric motor ware the noise filter is removed would do the trick but there are properly better solutions)
2. read up on how others do there testing
www.hardwaresecrets.com/article/410
http://www.xbitlabs.com/articles/other/display/psu-methodology2.html
http://www.anandtech.com/show/2259
http://www.hardocp.com/article/2007/02/25/hard_look_at_power_supplies/
These are imho the most reliable sites when it comes to PSU testing, and its better to steal good than then come up whit something bad your self, do it looks pretty good for the most part, and i hope i can put THG in the same list of sources if i am looking for a new PSU.
3. If possible make the whole testing fully automated ore as mouths as possible, so you can do a lot of testing quick and whit out human error.
4. make a interactive database ware you have a X and Y graph ware you can select self X and Y, and next to it sliders ware you can adjust the minimum requirements for the PSU your looking for.
And good luck whit the testing program i would say.
