Sure, though you shouldn't need to disable the onboard device. All you really need to do is switch the default output device from the Windows Control Panel, unless there is a driver conflict.
^^ No, it won't. Having it installed and not using it saves NOTHING.
I have 4 seperate sound devices installed right now:
ASUS Xonar Xense
NVIDIA HD Audio Output [from GPU]
Onboard Realtek
Logitech G35 [not using, but still plugged in]
