Sound Blaster Recon3Di driver being weird
Angelz
342
Hi. I have a problem here that just started up. Onboard my Gigabyte G1. Sniper 3, my Sound doesn't want to work anymore when plugged into the sound jack (green) like normally. When i disable the Sound Blaster Recon3Di driver, i hear sound, but when it's enabled, i don't hear sound anymore. However if i plug the jack in the front of the tower, it works fine with the driver enabled. What in the world? O___o If someone can help me figure this out i'd greatly appreciate it. I don't even understand why this is happening. I never messed with the sound settings. X_x
One thing.. You said you are using the front ports on your case right? Are they fully connected to the motherboard? Not loose or anything?
Okay, i put it on. Still no sound working on the motherboard's rear port. But the audio on the front from the tower itself is allowing it to work. -_____-
By the way, not that it helps any, this is a Cosmos II Ultra Case.
odd indeed. 😵 maybe a short? do you know, was the board they sent you back a brand new board or a refurbished one?
i personally have an issue with my Creative Sound Blaster X-Fi Xtreme Gamer card with ventrilo but that is a ventrilo issue. i restart ventrilo then all is well for a short time. there may be some issues with drivers. are there updated drivers for that board on creatives web site?
