Sound Blaster Z, Zx or ZxR?
RealitySpeaks
88
So after reviewing all my components, I shaved off about 200-300$ off and I was thinking about investing in a Sound Blaster sound card. I am an audiophile and I have been told that my MoBo: Asus P9X79 Pro doesn't have the most fantastic sound ever. So I would love to hear your suggestions on the following: Should I buy one of these cards? If so, which one and why. Or should I skip a sound card all together? Thanks alot!
Your card supports 32-bit integer inputs, but has only a 24-bit DAC. Most older audio codecs are designed around 16-bit inputs and may not function properly if fed 24-bit or 32-bit inputs.
It's very hard to tell the difference between a 16-bit input that's upscaled to a 24-bit output and a native 24-bit input. It's impossible to tell the difference between a native 24-bit input and a downsampled 32-bit input.
Hi
Same problem here
Install latest drivers: SBXF_PCDRV_L11_2_18_0015A
Set the SB console how you like it then put computer to sleep.
Then wake and shut down. (not restart)
Turn computer back on & console should remember settings.
At least mine did
This problem drove me mad but has worked 100% since trying this.
I believe its something to do with the speed of a restart not allowing the respective settings to be saved..
Tell me if this works
Thats the ONE reason why I still tend to recomend the DX at the sub-$100 price point. For headphone use though, the Z is a much better option then the DG(X), despite its higher price.
The DX/Z are so good, its kinda hard to recommend anything else in most cases below the super-high end (STX/Phoebus/ZxR); middle just doesn't offer enough to be attractive.
(Still rocking my Xense)
Dear, set your desired audio settings & then you have to standby your PC for one time & wake-up again. This will save your preferred audio setting. But whenever you make changes to the audio settings, you have to do this again. Windows save the audio settings when you standby the PC, It is a driver bug for this series of cards.
I own same card & its works.
Thanks...
First off I am a gamer so the computer discrete sound cards I choose their top priority is the 3D surround environmental position gaming, I am also an audiophile but I do not use my computer for that, I use my home stereo.
I also have 2 DJ computers dedicated to audio sound output, but they both run M-Audio dedicated stereo sound cards.
When it comes to gaming sound cards Creative is the master period!
I had my eye on the Sound Blaster Z for quite some time but until Newegg dropped $40.00 off it's price I stayed with my X-FI Extreme Gamer Fatal1ty Pro and I really still wasn't sure I was not wasting my money, however after running it on Win7 and gaming with it, I have to say the Sound Blaster Z is one of the best gaming sound cards from Creative yet.
It also plays back music quite nice as well, but it is not dedicated to that, so the ZX or above would be what you'd want if you have no interest in gaming.
Talk is cheap but hearing is believing!
My 2 cents! Ryan
If you have the windowed pc case and if you care about the look inside the your pc case than i dont recommend the ZXR, because that Ugly Connector to the daughter Card, they should of made the connector like SLI or something, but they made the connection on the long card at the and and also the daughter card has the connection at the end, but they should of place the connection on the long sound card at the front to line up with the daughter card, and make a smaller connector, or just make a much longer connector, so than you can hide the connector behind the sound cards, but the quality is good, so maybe i just sell this one and get the ZX, cause its petty much same quality and just one Sound Card and it looks much better than 2 sound cards with the Ugly Connector...
