Sound card clipping?
cowgod2007
123
Hey guys,
So I'm recording a very low frequency in Audacity ~60 Hz. However, it should be a perfect sinusoidal wave when I record but it clips at the peaks and the peaks become square-ish rather than round. I'm thinking its the sound card because I've tried the input on different computers and get different, better looking sin waves and recordings.
Can anyone give me some input? Maybe the sound card doesn't record at that low of a frequency? Maybe its distorting the sound? I've tried playing around with the recording volume and lowering it does help, but its still not nearly as good as I would like. My laptop is a dv6t-qe with beats audio (I tried looking up the exact name of the integrated sound card but I can't find that or the specs).
Thanks in advanced!
It's hard to say for sure but, integrated laptop soundcards aren't known for great low frequency range since neither the laptop speakers or the external speakers most people hook up to it can reproduce that range. The fact that the sine wave has a square-ish instead of a rounded peak also suggests that your internal sound card has reached some sort of limiting factor, very possibly the design it's self.
If you really need to record below 60 Hz, I would suggest a external USB soundcard.
Hi cowgod,
1) what is the source of your 60Hz signal?
2) How are you feeding this source into your soundcard? what leads?
and re-check the input connection (line in? mic in? mic boost on? etc)
3) How does the amplitude/volume level 'look' in audacity - do yo need to vertically zoom in alot to see this wave? ....i.e. is the input gain non-optimal?
4) Are you able to boost the signal going into the soundcard i.e. at source (outside the pc)?
5) just an educated guess - are you trying to remove 60Hz mains noise from a recording?
6) what is the soundcard?
7) have you tried recording into a different wave application e.g. sound forge?
That's what I was thinking. We have a cheap microphone in our lab that records from 40Hz - 19,000 Hz but starts to distort/clip at 40-70Hz, similar to what happens on my laptop. We're thinking the same, lowend sound card is the problem but I just want to make sure before I jump to conclusions because the clipping is slightly different (could just be how its processed).
1) I'm doing research and I'm using transisters and resistors to transform electricity from a power main into a signal that is able to be read through a computer. Basically a "microphone for electricity"
2) Through the standard 3.5mm jack. Checked input connections, all seems to be in order
3) I do need to zoom in to see it but I don't need to increase/decrease scales to see anything fine.
4) N/A signal is constant
5) nope, sorry lol
6) Its an integrated soundcard (don't know too much about soundcards and specs). I tried doing a little research, but couldn't find much. Its on my HP DV6T quad edition and it has "beats audio". I've read somewhere the beats audio is just a rebranded intel integrated audio.
7) Nope, but I'll definitely try that. I don't see it being too big of a difference though
two quick thoughts:
have you tried MOVING the microphone?
can you put a parametric EQ in the signal chain? (actually a compressor would better.)
You're not responsible for putting that damn mains noise into certain venues (and recordings) my old band used to play in? - a pain in the ass trying to get rid of it! lol
A few more daft questions......
1. Are you recording amplified audio directly from a speaker? If so, is the speaker rated to deliver a 60Hz audio signal with plenty headroom (using a dedicated bass speaker?)
2. Check that your mic is recording in it's optimal axis position and that it is placed optimally next to the speaker.
3. Is it also possible that 60Hz is getting too close to the mic's low limit? (a higher quality mic will better guarantee signals between these limit boundaries)
4. Try a different mic
5. Have you tried feeding the signal (for test purposes, must be the same signal the mic captures) into an Oscilloscope to confirm it's quality (will help with optimal mic placement)?
6. If all else fails, try a dedicated soundcard/audio interface - borrow one to try out.
7. Was this set-up identical when used with any of the different computers? and, what soundcard or motherboard were they using?
8. One last idea, try recording the output of a tone generator with this set up, sweeping down to the mics lower limit, then checking the waveform.
There isn't really a "microphone". If you look at my previous post, its taking a constant frequency (electricty from an outlet) and converting it into a readable "noise" frequency/signal that is fed directly into the computer through the standard audio jack. I don't know much about audio stuff but I would suspect using an EQ wouldn't help much? But idk.
1) No, its not amplified. But its definitely processed through transister and resistors.
2) N/A the mic doesn't actually record any "sound" so positioning and other noise interferences won't matter
3) N/A there's no actual mic lol
4) We would have to build another lol
5) No, might be something to look into. I would need to get an oscilloscope first though...
6) Yea, what do you think about an external USB soundcard or something of the sort?
7) No, setup was different (different soundcard, on a dell desktop)
8) Will try, won't hope for too much.
At this point, I'm thinking its the physical limitations of the sound card/codec/processor.
Does anyone know a way to get the input through a higher quality, more sensitive mic and then into the PC? So instead of "mic" input --> PC, it would go like input --> high quality mic --> PC
Also, any opinions on external sound cards? Will an external card be of higher quality/same quality as an internal? If I go expensive enough, will external sound cards be able to accurately measure/read low frequencies like 60Hz?
ok, first off you did mention a mic:
but didn't understand you weren't using a mic.
now let me put it to you this way; when something is called a MIC IN it means it is configured for a MICROPHONE.
whatever you are doing you don't know what you're doing.
please stop.
[looniam......I'm pretty much thinking the same thing 😉....his response to the following will confirm]
Is an actual microphone involved? (and thus, a digital-analogue conversion step....followed by an analogue-digital conversion for the pc)- when you said earlier:
"We have a cheap microphone in our lab that records from 40Hz - 19,000 Hz "
.....and now say
"Does anyone know a way to get the input through a higher quality, more sensitive mic"
.....it pretty much suggested one was, hence our replies.
Internal/External sound cards/audio interfaces : there are many - the more expensive ones, of course, use higher quality components. I currently use a TC Electronic Studiokonnekt48 for various projects. This would be a bit of an overkill for your specific application, however, I would recommend seeing if you can hire a good quality audio interface from your local pro music shop.
Amongst other benefits, the D-A/A-D converters (if you need to use them!) will be much higher quality and, importantly, operate with a much higher resolution. The resulting signal can be passed into your pc using an appropriate link (e.g. firewire in my case, usb, or spdif, etc).
For the cost of 1 day's hire I would try these out (guaranteeing quality components 1st) - you may find you don't have to spend too much on a permanent replacement, heck, you might find that a cheaper creative x-fi card would do.
Back to the mic question (if one does exist, lol), for - as you say - a "a higher quality, more sensitive mic", see the same shop as above, but of course, ensuring you ask for a model fit for purpose.
Ah.....one last thing......take a few detailed photos of your set-up & post here.
Yeah, I don't. I'm working at an electrical engineering lab at a university doing research. Maybe I'm the reason why America is so far behind in science and you can help us back up?
And let me put it to you this way. We aren't looking at sounds. We are looking at electricity, specifically from an outlet. We built our own hardware to transform it down to a usable level and feed it directly into the audio jack so it doesn't blow up our computer.
Sorry, we were using a handheld mic (Olympus ws-700m) that we fed the signal directly into, then put on our computer. We also tried feeding the signal directly into our computer's audio jack. Both have clipping but to various degrees. Sorry for the confusion. And I think I've narrowed down the problem to the sound card and I'm going to do some testing with various external sound cards.
again what you are completely failing to understand is that you are taking a signal that is extremely harsh, noisy, and has a lot of ripple and trying to process it through sensitive bandwidth processing.
do know why you are having a problem with 60hz?
because that is the frequency of electricity.
now, did i just saved america?
if you want to listen to electricity get a oscilloscope!
Actually, with the right transistors/resistors/circuitry, the signal is easily readable. I have a computer and the input is read in perfectly with no clippings. And the frequency only fluctuates between 59.90Hz and 60.10 Hz.
And oscilloscopes are all fine and dandy. Until you want to do mass testing.
No you didn't save America because your answer was only slightly correct and mostly incorrect.
while 120V AC is indeed 60Hz or cycles per sec. other AC voltages are not and (normal) DC has no frequency.
I believe the OP want's to record the sound of electricity not measure the cycles per sec which is a different thing all together. I'm not sure why the OP wants to record the sound of electricity but, I'm sure he has his reasons.
So in the spirit of the OP's question(s) and of course saving America LOL, I'll try to answer the best I can.
As long as your mic is capable of going lower than 60Hz, IMHO the only other hardware that could be limiting you is your onboard recording hardware (and possibly software).
I always buy higher end soundcards that are all capable of 20Hz however you need far less if you just need one channel capable of recording low frequency's and playback is not much of an issue so it's real for me hard to give you a recommendation.
Certainly something like this: http://www.amazon.com/M-Audio-MobilePre/dp/B0041OSWX8 should do the trick but you might be able to find something cheaper if you look around.
Exactly! - taken straight off my previous posts...lol....though I'm sure were finally getting there 😉
Is this the mic: http://www.olympusamerica.com/cpg_section/product.asp?product=1515&page=overview ---> you may have introduced serious component/converter quality issues in this single link.
Please, again, detail exactly how you use this mic - do you record using the mic or mic-in feature - and describe how.
In any case, you are including (very) basic audio engineering into your setup !! fact !! - thus the use of audacity or, as I use (and other pros primarily use), sound forge.
Now, since we've established the use of a mic (finally), this of course means recording an analogue signal (if using the 'mic' component...see above, converted from your digital source - see later)......coupled with a digital conversion to go into the pc !!! ........now please re-read messages before. I doubt that any signal will 'pass through' this 'mic' in a pure format - i.e. converters will be at play irrespective of how you use this mic.
Here's another (educated?) idea!! - try bypassing these D-A and A-D converters (assuming your 'original' signal sits - at some point early - in the digital domain) and see if you can pass the signal into an audio interface that accepts a digital input (most do!) ----> with this you are removing a set of variables (converters + mic) ---->sounds dooable/good? You may (or may not) need to play about with getting a digital 'lock' - I'll not say any more on this however, you are working in an electronics uni department (e.g. frequency converters hint hint)
The use of an oscilloscope must be included for initial setup / validation purposes, thereafter you're good for the mass run.
p.s. please send some of your profits from this to us (mass run etc) 😉 😉
Yea, we're looking into doing testings with cheap external sound cards and if the clipping is consistent across all machines, then we know the problem lies in the sound card and we will have to get a higher quality one.
How would I bypass the D-A and A-D converters? I'm not too knowledgeable on the intricacies in sound cards but don't you need to go through the DA/AD converters to turn the analog signal into a digital one, which allows it to be read into a computer? The signal is no help if I can't analyze it/modify the signal on a computer.
P.S. No profits on my side. I'm researching in a public university so unless a professor decides to patent/copyright this idea, I think this research/information will be public domain.
and i am incorrect where?
this is not simply a matter of being able to throw money at it to solve the problem. the problem is using an incorrect method of gaining a "readable" sample.
until the OP can LOWER the SIGNAL STRENGTH it does not matter how fancy or expensive the sound card is, it will inherently overload the 60 Hz. (the frequency of electric in north america.)
now if the OP is successful in their endeavor it will be a red letter day for live audio engineers world wide; for they would never have to worry about a ground hum again.
until then have fun chasing your tail . .
I am lowering the signal strength...We build custom hardware to transform the power since we get our electricity directly from an outlet and feeding that into our computer could possibly blow it up or at the best case, destroy it. I think I said that somewhere...no more bickering ok?
There is no way to do this. All storage medium on a computer is digital only, this includes very temporary storage like ram (not usually considered storage). There is simply no way for analog to be recorded on a PC without first converting it to digital then back to analog before it is played through speakers.
The only way to "bypass the D-A and A-D converters" on your sound hardware is to feed it an already converted (to digital) signal on the way in and a digital signal on the way out that still needs to be converted to analog before it can be played.
While this could be of benefit if the onboard DAC's are of particularly poor quality and all PC speakers with a digital input can accomplish the final conversion to analog, you would still need to have a DAC for the initial conversion from your analog mic to digital for your PC. A separate DAC for this (initial conversion) would cost as much or more than a external sound card that could handle both conversions. Also most mid-level soundcards have much better DAC's than PC speakers or onboard soundcards have and you are probably measuring the low end frequency at the PC/before the speakers anyway.
Easy looniam, I was just pointing out that electricity has more variables than 120V AC. With the whole "saving America" thing, I thought my response was lighthearted. If it came across as anything else, it wasn't meant that way.
That makes more sense. That's what I was thinking because currently my input is analog. Sorry for not specifying, I thought it was assumed.
No probs, cowgod
I'm starting to repeat myself, and, getting the impression that the full start-finish responses that have been posted haven't been fully read before some comments.
e.g -->
"bypassing these D-A and A-D converters (assuming your 'original' signal sits - at some point early - in the digital domain) and see if you can pass the signal into an audio interface that accepts a digital input (most do!) ----> with this you are removing a set of variables (converters + mic)"
--> in reading my earlier posts, and specifically, the repeated unanswered question "Please, again, detail exactly how you use this mic - do you record using the mic or mic-in feature - and describe how. " (this mic offers >1 input method!!!).................
-->We all need to know how you are using this mic:
1. Placing it against a speaker? - if yes, please describe the setup
2. Feeding a 'signal' into it's 'mic in' socket (see - I did have a glance over its manual) - if yes, are you performing a D-A conversion process beforehand (loaded question)? - if yes, then you 'might' not need to and thus you could bypass at least 2 DAC steps IF you could get the ORIGINAL digital signal 'directly' into your pc - you may need to employ a suitable D-D conversion to get the signal to talk to your pc spdif (if it has one) or the audio interface D input. --> thereby BYPASSING any D-A then A-D steps. This is just a suggestion and you may need a custom D-D converter (unless an appropriate one exists)....and this is where your field comes back into play.
p.s. of course pc's operate in the D domain....... 😉
Anyway, please don't be offended by any 'implied' tone - it's sometimes damn difficult condensing a multitude of thoughts down into a few lines - oftentimes we all over-assume in life :)
I think your best next step would be to see if anyone at the university has a decent external sound card you could borrow and try.
P.S. No offense by any 'implied' tone "mesab66" and please don't take any on mine. Just trying to save my country. 😀
if you are going to tell me i am incorrect, then kindly point out the flaw. after 12 years of audio engineering in a live production environment; i do know what electricity is thank you very much. i also know a thing or two about signal processing and what can and cannot be processed by a given means. so if those experiences and the knowledge believe i gained through such has led me to draw erroneous conclusions; i beg of you to be so kind as to straight them out as opposed to just saying they are wrong without a explanation.
its the sake of the country at stake ya know or "Idonno"?
just don't try to feed me a hubris statement and claim to being lighthearted :non:
Latest posts
