G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I have a Williams Sorcerer systems 9 game. It worked
for one game. The second game (the second 'power on') the volume was cut in
half. Using science, I determined flicking the power switch on and off
several times may clear up the issue. 🙂
Now the sounds/speech are at extremely low levels. While runnig the sound
test via the diagnostics, you cannot hear the sounds unless my ear is right
against the speaker. There is no electrical hum - nothing. Just some very,
very faint sounds.
I've played with (without replacing) the volume pots on both the coin door
and sound bought. Again using the most advanced scientific method known to
me, I've diddled with the connectors, wiring, EPROMS, etc....
I have not yet started replacing any components. I wanted to solict some
advice first. Any help would be
apprecited in diagnosing the problem.
Thanks,
Bill
very faint sounds.
Thanks,
Bill
