System Information
Time of this report: 12/7/2011, 09:19:38
Machine name: USER
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.060411-1541)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: n/a
Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs)
Memory: 494MB RAM
Page File: 531MB used, 625MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82865G Graphics Controller
Manufacturer: Intel Corporation
Chip type: Intel(R) 82865G Graphics Controller
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_2026107B&REV_02
Display Memory: 96.0 MB
Current Mode: 1024 x 768 (32 bit) (85Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ialmrnt5.dll
Driver Version: 6.14.0010.4363 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/1/2006 11:33:22, 38014 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ialmnt5.sys
Mini VDD Date: 4/1/2006 11:33:22, 1049180 bytes
Device Identifier: {D7B78E66-6632-11CF-C062-2C00A3C2CB35}
Vendor ID: 0x8086
Device ID: 0x2572
SubSys ID: 0x2026107B
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/5/2006 19:40:32, 57984 bytes
| Driver: usbd.sys, 8/4/2004 18:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 18:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 18:00:00, 24576 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 7/6/2006 13:50:16, 23040 bytes
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
System Devices
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to PCI to CSA bridge - 2573
Device ID: PCI\VEN_8086&DEV_2573&SUBSYS_00000000&REV_02\3&267A616A&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2585 (English), 10/17/2005 22:36:26, 68224 bytes
Name: Intel(R) 82865G Graphics Controller
Device ID: PCI\VEN_8086&DEV_2572&SUBSYS_2026107B&REV_02\3&267A616A&0&10
Driver: C:\WINDOWS\system32\DRIVERS\ialmnt5.sys, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 1049180 bytes
Driver: C:\WINDOWS\system32\ialmrnt5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 38014 bytes
Driver: C:\WINDOWS\system32\ialmdnt5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 116859 bytes
Driver: C:\WINDOWS\system32\ialmdev5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 212090 bytes
Driver: C:\WINDOWS\system32\ialmdd5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 899706 bytes
Driver: C:\WINDOWS\system32\igxpxa32.cpa, 4/1/2006 11:33:26, 524850 bytes
Driver: C:\WINDOWS\system32\igxpxa32.vp, 4/1/2006 11:33:26, 900 bytes
Driver: C:\WINDOWS\system32\igxpxk32.vp, 4/1/2006 11:33:28, 58675 bytes
Driver: C:\WINDOWS\system32\igxpxs32.vp, 4/1/2006 11:33:28, 18496 bytes
Driver: C:\WINDOWS\system32\hccutils.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 73728 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 57344 bytes
Driver: C:\WINDOWS\system32\igfxsrvc.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 159744 bytes
Driver: C:\WINDOWS\system32\igfxpph.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 147456 bytes
Driver: C:\WINDOWS\system32\igfxcpl.cpl, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 77824 bytes
Driver: C:\WINDOWS\system32\igfxcfg.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 438272 bytes
Driver: C:\WINDOWS\system32\igfxdev.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 135168 bytes
Driver: C:\WINDOWS\system32\igfxdo.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 86016 bytes
Driver: C:\WINDOWS\system32\igfxtray.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 163840 bytes
Driver: C:\WINDOWS\system32\igfxzoom.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 114688 bytes
Driver: C:\WINDOWS\system32\hkcmd.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 155648 bytes
Driver: C:\WINDOWS\system32\igfxress.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 1503232 bytes
Driver: C:\WINDOWS\system32\igfxpers.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 114688 bytes
Driver: C:\WINDOWS\system32\igfxrara.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 122880 bytes
Driver: C:\WINDOWS\system32\igfxrchs.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 81920 bytes
Driver: C:\WINDOWS\system32\igfxrcht.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 81920 bytes
Driver: C:\WINDOWS\system32\igfxrdan.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrenu.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 135168 bytes
Driver: C:\WINDOWS\system32\igfxresp.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrfin.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrfra.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrheb.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 118784 bytes
Driver: C:\WINDOWS\system32\igfxrita.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 151552 bytes
Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 98304 bytes
Driver: C:\WINDOWS\system32\igfxrkor.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 98304 bytes
Driver: C:\WINDOWS\system32\igfxrnld.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 147456 bytes
Driver: C:\WINDOWS\system32\igfxrnor.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrplk.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrptb.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrptg.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrrus.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrsve.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrtha.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 126976 bytes
Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
Driver: C:\WINDOWS\system32\igfxrell.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 155648 bytes
Driver: C:\WINDOWS\system32\igfxrhun.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 135168 bytes
Driver: C:\WINDOWS\system32\igfxext.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 98304 bytes
Driver: C:\WINDOWS\system32\igfxexps.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 36864 bytes
Driver: C:\WINDOWS\system32\ialmrem.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 49152 bytes
Driver: C:\WINDOWS\system32\iglicd32.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:26, 2310144 bytes
Driver: C:\WINDOWS\system32\igldev32.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:24, 524288 bytes
Driver: C:\WINDOWS\system32\ialmudlg.exe, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 114688 bytes
Driver: C:\WINDOWS\system32\ialmuARA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuARB.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuCHS.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuCHT.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuCSY.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuDAN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuDEU.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuELL.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuENG.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuESP.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuFIN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuFRA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuFRC.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuHEB.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuHUN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuITA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuJPN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuKOR.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuNLD.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuNOR.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuPLK.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuPTB.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuPTG.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuRUS.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuSVE.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuTHA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\ialmuTRK.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
Driver: C:\WINDOWS\system32\iAlmCoIn_v4363.dll, 1.00.1000.0001 (English), 4/1/2006 11:33:22, 61440 bytes
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&267A616A&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_2026107B&REV_02\3&267A616A&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2891 (English), 6/17/2006 22:43:54, 20608 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2891 (English), 7/6/2006 12:43:06, 143360 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2846 (English), 3/5/2006 19:40:32, 57984 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_2026107B&REV_02\3&267A616A&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2891 (English), 6/17/2006 22:43:54, 30080 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 18:00:00, 7168 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers - 24DB
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_2026107B&REV_02\3&267A616A&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\intelide.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:42, 5504 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 18:00:00, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 01:59:44, 95360 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_2026107B&REV_02\3&267A616A&0&EA
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_2026107B&REV_02\3&267A616A&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_2026107B&REV_02\3&267A616A&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_2026107B&REV_02\3&267A616A&0&E8
Name: Intel(R) 82801EB Ultra ATA Storage Controllers - 24D1
Device ID: PCI\VEN_8086&DEV_24D1&SUBSYS_2026107B&REV_02\3&267A616A&0&FA
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&267A616A&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 18:00:00, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&267A616A&0&F0
Name: Intel(R) PRO/1000 CT Network Connection
Device ID: PCI\VEN_8086&DEV_1019&SUBSYS_2026107B&REV_00\4&26062112&0&0818
Driver: C:\WINDOWS\system32\DRIVERS\e1000325.sys, 8.05.0014.0000 (English), 4/1/2006 11:33:08, 177152 bytes
Driver: C:\WINDOWS\system32\Prounstl.exe, 8.00.0007.0000 (English), 4/1/2006 11:33:10, 126976 bytes
Driver: C:\WINDOWS\system32\e1000325.din, 4/1/2006 11:33:16, 2745 bytes
Driver: C:\WINDOWS\system32\IntelNic.dll, 8.02.0009.0000 (English), 4/1/2006 11:33:28, 23040 bytes
Driver: C:\WINDOWS\system32\e1000msg.dll, 8.05.0012.0000 (English), 4/1/2006 11:33:16, 163840 bytes
Driver: C:\WINDOWS\system32\EtCoInst.dll, 2.02.0001.0000 (English), 4/1/2006 11:33:08, 17408 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 18:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 18:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 18:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 7/6/2006 13:50:16 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 18:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 18:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 18:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 18:00:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 20480 bytes
qasf.dll: 11.00.5358.4827 English Final Retail 5/30/2006 22:11:06 201728 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 279040 bytes
qdvd.dll: 6.05.2600.2831 English Final Retail 2/19/2006 05:01:10 386048 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 733696 bytes
quartz.dll: 6.05.2600.2905 English Final Retail 6/17/2006 22:43:52 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 18:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 18:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 18:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 18:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 18:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 18:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 18:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 18:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 18:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 204288 bytes
ks.sys: 5.03.2600.2818 English Final Retail 12/28/2005 21:29:30 141056 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2790 English Final Retail 11/4/2005 21:55:10 48768 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 7/6/2006 13:50:16 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 7/6/2006 13:50:16 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2905
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2905
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5358.4827
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2905
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2905
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2905
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2905
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2905
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5358.4827
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2905
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5358.4827
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2905
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5358.4827
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2905
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2831
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2905
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2905
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5358.4827
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2831
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2831
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2905
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5358.4827
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5358.4827
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2831
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2905
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2905
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2905
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5358.4827
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2905
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2905
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2905
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2905
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2905
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2905
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2905
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2905
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2905
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2905
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2905
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2905
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2905
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2905
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2905
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2905
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2905
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2905
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2905
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2905
these are my system requirements. i m using Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.060411-1541)....
