Sound
Thomas
449
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Having trouble with sound when playing a dvd if working but skipping and
jumping when playing a DVD
works fine all other times .
will also do it when making a DVD and computer calls for any kind of
sound .
Just started this . I reloades the drives but no help.
Thanks
>sound .
> Thanks
I've never had that problem but you should post your system specs so
others may be able better help you.
good luck,
Ed
Your problem isnt that unheard of... As far as I know, there is
nothing u can do. You can reload windows and drivers as much as u
like.!
I suggest u get that board back to the retailer u bought it from
A.S.A.P! U can still use the warranty if it isnt too old.
I think there could be something wrong with the chipset on the board.
Good luck!
