Archived from groups: microsoft.public.windowsxp.basics (
More info?)
Well the wonders of PC's. Carried out your suggestion,
all worked with drivers dated 01/07/01 - version
5.1.2001.0, I then created a restore point and loaded the
latest drivers as you suggested 61.76 and guess what,
card stopped working again. Gone back a stage all working
fine and leaving well alone.
I thank you, for all your help
>-----Original Message-----
>Hi
>Try this:
>Go into Device Manager and uninstall your graphics
card. Then reboot and
>let Windows re-detect it. You can then install the
updated drivers.
>Will Denny
>MS-MVP Windows - Shell/User
>Please reply to the News Groups
>"barry" <anonymous@discussions.microsoft.com> wrote in
message
>news:d0ad01c48a91$d9c899f0$a601280a@phx.gbl...
>| I have downloaded and installed the drivers that you
have
>| suggested and I am still having the same problem.
Message
>| on device manager - this device cannot start (code 10)
>| >Hi
>| >Version 61.76 are for XP/2000:
>| >http://www.nvidia.com/object/winxp_2k_61.76.html
>| >Will Denny
>| >"Joe727" <nospam@nospam.nospam> wrote in message
>| >news:%23n7vbuoiEHA.1344@TK2MSFTNGP11.phx.gbl...
>| >| The latest drivers for XP are 61.77 (the 61.76
drivers
>| are for Windows
>| >98).
>| >| You can download the 61.77 drivers here:
http://www.nvidia.com/object/winxp_2k_61.77
>| >| You also should update your motherboard chipset
>| drivers if an update is
>| >| available.
>| >| Joe
>| >| "Barry" <anonymous@discussions.microsoft.com> wrote
in
>| message
>| >| news:d01c01c48a8a$56fe68d0$a601280a@phx.gbl...
>| >| > Hi,
>| >| > the version I have listed in device manager is
>| 5.6.7.3
>| >| > dated 07/04/2004, not to
>| >| >>Hi
>| >| >>What version of the Nvidia drivers are you
using? On
>| >| > the SP2 partition here
>| >| >>I have version 61.76, which aren't causing any
>| problems.
>| >| >>Will Denny
wrote
>| in
>| >| > message
>| >| >>news:5ae801c48a87$6510bbb0$a301280a@phx.gbl...
>| >| >>| I have just installed SP2 and I am now
experiencing
>| >| >>| problems with my GeForce graphics card -
message in
>| >| >>| device manager -unable to start - tried all the
>| normal
>| >| >>| things, removing the card - cleaning the edge
>| >| >>| connections - all to no avail. Any ideas? I am
also
>| >| >>| unable to use System Restore to go back pre SP2
>| install
