Speed depends on Processor frequency or cache memory ?
G
Guest
Guest
What is more important to make a Computer run smoothly at high speeds..... The cache memory or Processor Frequency ?.... Do higher frequency processors produce more heat ? If so, should I look for lower frequencies with high cache memory ?
Typically a lower clocked CPU will have less heat than the same CPU with a higher frequency, yes. However I wouldn't let that scare you from the higher clocked CPUs.
Frequency and Cache are both important factors in smooth computing. I would look for a mix between high cache and frequency.
Maybe you can tell us your budget and needs and we can help you find one.
Uhmmmm can someone tell me which of these laptops is better for school and medium gaming?
http://www.bestbuy.com/site/olspage.jsp?id=cat13504&type=page&pageIdentity=searchDriven&useProductString=true&productString=1218367936449*1218367939608*1218353394205&unProductString=1218321951290*1218317762845*1218349684658*1218202473595*1218325485331*1218296198127*1218217430159*1218370448855*1218355306087*1218353392824&catId=
