My cpu fan goes %100 for 4 seconds when Speedfans begins, then normal. My settings and temps are OK in speedfan, I control my speeds with "advanced fan control" technique.
This is not a big problem, but I wonder is there a fix for this?
My motherboard is 10 years old. [gigabyte ga-g31m-es2l]
I have smart fan option in bios, but in smart fan mode fan runs at high rpm at idle, and it makes some noise. In speedfan, I can make better speed and noise control.
well, the apps age isn't a reason. It might be that it takes 4 seconds or so for windows to hand control of the fans over to speedfan when you start it up.
Has it always been 4 seconds or is this a new thing?
Settings of speedfan are complicated for me. It took 2 weeks to control my fan. I'm using advanced fan control graphic. I have this problem since I control my speeds. It is always 4 seconds, when loading speedfan.
This is a strange bug, or there is some setting I can not find.
