spoolsv.exe reach a high level of CPU usage, cause slow pe..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
environment:windows xp table pc with Service Pack 2 in English version, Office
professinal 2003 in English version.
sympton: the CPU usage of process of spoolsv.exe was extremely high almost
at 90%
continuously. This cause windows low performance and user can't do anything
at
that time. With further check, I foud that in this folder
system\spool\printers,
there are some temp file exist.The name of these files are 000002.SHD,
00002.SPL,
00003.SHD, 00003SPL, etc. First I stop the printer spooler service and delete
thest temp file. and then restart the spool service. It seems I solved the
problem. But after some time later, the temp file appears again, spoolsv.exe
CPU
usage also reach a high level. Slow performance come back again.
Question: How to solve this problem, and what's the reason.
Thank you very much.
spoolsv.exe
Is malware. Here is a description at Trend Micro;
'BAT_ZCREW.E' (http://tinyurl.com/c99aw)
You can go to 'HouseCall' (http://housecall.trendmicro.com/)
and do a free online scan & removal. Hope this helps you out.
Best,
Treeman
Treeman
Treeman's Profile: http://www.msusenet.com/member.php?userid=1260
View this thread: http://www.msusenet.com/t-1870436886
Lasso, I am experiencing similiar issues on my PC. Task manager indicating
49% of system resources dedicated to print spooler. Causing significant slow
down. I am using Win XP pro. I could not find any virus, trojans or
spyware......... I am currently turning off print spooler services to
recapture lost resources (P4 3.2 mhz)
Searching for a solution....... may have to do a re-install?????
-Art
> at 90%
> at
> 00002.SPL,
> CPU
