[SOLVED] SSD Problem
Aug 9, 2020
20
I can't install anything in my ssd. Even windows 10, I tried doing some research and I got this error.
C:\Windows\system32>diskpart
Microsoft DiskPart version 10.0.16299.15
Copyright (C) Microsoft Corporation.
On computer: DESKTOP-ID1O7J7
DISKPART> list disk
Disk ### Status Size Free Dyn Gpt
Disk 0 Online 465 GB 1024 KB
Disk 1 Online 465 GB 1024 KB *
Disk 2 Online 223 GB 0 B
DISKPART> select disk 2
Disk 2 is now the selected disk.
DISKPART> clean all
DiskPart has encountered an error: The request failed due to a fatal device hardware error.
See the System Event Log for more information.
DISKPART> exit
Badly need help, I currently have my Windows 10 in my HDD which is very slow. I want to try cloning it but I need your suggestions.
Hi, While installing windows I got some problems, it said "Windows cannot be installed to this disk. The selected disk has an MBR partition table. On EFI systems, Windows can be installed to GPT disks"
During the install, you need to DELETE all existing partitions, and continue with a clean drive.
Since you know how to use Diskpart =
-while in Window installation, press SHIFT+F10 to prom CMD.
-in CMD "diskpart", clean that HDD
-exit the CMD and refresh the Expansion List
I did this but it said "
See the System Event Log for more information." And SSD became unallocated again.
Can I get your discord? Anyone who I can contact to have some guide, please (of that's possible)
is saying hardware error, you going need some kind software with Deep Cell check on HDD and sry, i'm am working right now and probably able to do so by next 4 hours
