Hi all, I received a stack-based buffer overflow error on my PC yesterday. I am fairly tech savvy, but this isn't an error I have personally received before. I did some googling to see what the error is, how to fix it, and what could have caused it. I only received it once so far, so it's hard to say if I still have an issue for me. Not even sure how to check if that issue is persisting.
I am afraid there are some things I don't quite understand, so I was hoping some people could help clear them up for me. This is especially so here since I didn't get an error code and it is from textinputhost.
I have ran SFC and it said it found corrupt files and repaired them. I also made sure to install the latest updates for Windows. I ran windows defender full scand and it found nothing. I could try other virus/malware applications just in case.
It seems to me, that this error usually involves using a restor point, start up repair, or reinstalling windows completely.
The one suggestion I have seen constantly is to open MSConfig and to check what is running and what is enabled on start up. I am fairly dictatorial on what I allow to run and what I allow to be enabled on start up. Third party applications, while often useful, tend to run in the background when I don't want them to. So, I am not even sure how I have an issue if that is the place where these issues arise from - e.g. third part software.
Can someone explain this error to me and generally what one needs to do in order to resolve it, please? Just want to make sure I am doing the right things.
Any help or guidance would be highly appreciated! Thank you!
For those who may want to know I am running Windows 10 Pro on a Ryzen 3900X system. Not sure the hardware matters there.
Here is a link to the actual error I saved.
View: https://imgur.com/a/KwziDeX
