Hi, I have an old AsRock board with only 3 standard PCI 2.2 (not express) 32-bit interfaces as the only option for video upgrade. Would a 64/128/256 BIT CARD FIT IN a 32 bit slot. And would a standard PCI 3.0 fit in a PCI 2.2 slot.I want a shader3.0/4.0 512 mb card.I have found some cards.Please suggest which one would be compatible ?
His Radeon 5450 HD Silence 512 Mb PCI edition
PNY VCGFX522PEB GeForce FX 5200 256MB 128-bit DDR PCI Video Card
PNY GeForce 8400GS 512MB DDR3 PCI DVI+VGA+HDMI Low Profile Graphics Card VCG84512D3SPPB
If none are compatible suggest a card of your own. Just should have a 3.0 shader at least.
