So I will try and explain this the best I can. It has been going on for a few months now, and because it really does nothing besides pop up obnoxiously I have not done more than try and search on search engines for answers, but alas, I can find nothing definitive. I run comodo interenet security with antivirus, and malwarebytes for my malware, and have run both, and run malwarebytes in safemode and it has not found anything. Anywho on to the issue.
I get a pop up stating there is a 16-bit DOS cannot find or open file or some such on this. C:/WINDOWS/TEMP/314.exe. However that folder does not exist, nor does anything with 314.exe. It gives me the option to ignore or close, and I can find no discernible difference between either option. If anyone could give me any ideas, I would really appreciate it!. Thank you!
