Strange language in my System Configuration Utility
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
When I run "msconfig", then go into the System Configuration Utility, select
the "Startup" tab, there is a file in oriental language there. Checked or
unchecked it causes a dialog to come up at boot-up that says: Cannot find
the file (oriental xxxxxxxxxxx??? etc.). Search your computer for this file
and delete it if it is not needed. Also, delete the registry entry.
Problem: The Oriental writing in the Startup tab entry shows part of the
registry path (HKCU etc.) but not all of it. It will not let me highlight
and copy it so I cannot search for it. The Dialog that appears at startup
shows the oriental filename but also will not let me highlight and copy it
so likewise, I cannot search for it.
How can I get rid of the oriental file please?
Sincerely,
Jack Nation
Howdy,
You may search for hidden startup programs in the following registry entries
as mentioned in the below site:
http://windowsxp.mvps.org/Startup.htm
You may also like to try the Autorun utility as mentioned in the above site.
HTH
Venkatesh
> Sincerely,
> Jack Nation
Hi Jack,
Look for it under this key in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Jack Elvin" <nospam@nospam.mchsi.com> wrote in message
news:%23UyoLUw2EHA.1192@tk2msftngp13.phx.gbl...
> select the "Startup" tab, there is a file in oriental language there.
> Checked or unchecked it causes a dialog to come up at boot-up that says:
> Cannot find the file (oriental xxxxxxxxxxx??? etc.). Search your computer
> for this file and delete it if it is not needed. Also, delete the
> registry entry.
> highlight and copy it so I cannot search for it. The Dialog that appears
> at startup shows the oriental filename but also will not let me highlight
> and copy it so likewise, I cannot search for it.
> Sincerely,
> Jack Nation
Thanks Much To all who sent posts to help me. We have go it working right
for the moment. I honestly did not find the oriental file. I decided to
import an earlier backup that I had made of my registry and now the oriental
file is gone.
"Venkatesh [MS India Community Star]"
<VenkateshMSIndiaCommunityStar@discussions.microsoft.com> wrote in message
news:93FCA078-DAE1-4085-8EBB-AE678CEDC6C2@microsoft.com...
> Howdy,
> entries
> site.
> HTH
> Venkatesh
>> select
>> or
>> find
>> file
>> highlight
>> startup
>> it
>> Sincerely,
>> Jack Nation
