I've been having some strange issues with an old system I built a while back, and I'm thinking there may be something wrong with the MB, but I figured I'd get some other perspectives first before tossing this system. Here's the basic setup:
AMD Athlon XP, 2133 MHz (8 x 267) 2600+
MSI K7T Power/Pro/Pro2/Pro2-A/Turbo/Turbo2/Turbo Limited Edition
VIA VT8363A Apollo KT133A
1024 MB PC133 (SDRAM) as well as 1.5 GB PC100 (SDRAM)
FireGL T2-128 (128 MB) as well as a GeForce 5200 (256 MB)
Antec something-or-other 450 watt PS
A multitude of hard drives in Lian Li pull-out bays have been used. I had several OSs running on this, XP SP1, 2K SP2, and Suse Linux 9.2.
It started a while back when my XP SP1 drive started to reboot in the middle of startup. I'd see a quick BSOD blow by and then it would reboot and repeat indefinitely.
I changed some BIOS setting and managed to get the BSOD to stay, but it would be different every time. For instance, one was a Stop: 0x00000024, then a 0xFFFFFFFB, etc. When I tried installing an OS from scratch (either XP or 2K), I'd get a BSOD during some phase of the installation.
Thinking my memory was going, I replaced it with some PC100 ram I had. Nothing changed. Then I thought it may have had something to do with the graphics cards, so I changed the original GeForce for the ATI. No change. I directly wired an HD to eliminate the Lian Li bays out of the equation, which it did. Still had the same problem.
Now before I started hacking up the hardware, I should note that the Linux system always came up. The 2K system was also coming up, but then it too started crapping out. I have not tried starting Linux up since I changed the graphics card.
Eventually I managed to get another 2K setup up and running, and so far it's still cranking. I finally got an XP setup going, but the moment I ran SP3, off it went. BSOD.
I tried installing another 2K installation again today and got something a little different:
STOP: 0x0000000AZ (0x00000041, 0x00000002, 0x00000001, 0x8000414A)
IRQL_NOT_LESS_OR_EQUAL
Address 8000414A base at 80001000, DateStamp 381f8c6e - hal.dll
So anyway at this point I'm confused. Any ideas why this is happening? I can live without the XP setup on this box, but of course why is all this happening? Weird.
Thanks for any help with this.
